Page 19 of 29
FirstFirst ... 9 17 18 19 20 21 ... LastLast
Results 541 to 570 of 841
    Sep 2005
    Darkest Peru
    Anyone know if L3 & WVP2 will work on BroadwayHD? I've been thinking of signing up, but I don't want to if I can't get what I'm looking for.
  2. Every time I enable the Widewineproxy2 either in Chrome or Firefox, Amazon Prime says "browser not compatible"?
  3. Originally Posted by mac2132 View Post
    Widewineproxy2 is already falling apart, I can no longer install it on Chrome, it is incompatible, video materials stop downloading. And it was so good.
  4. Originally Posted by Henryk69 View Post
    Just checked it, it works on Ungoogled Chromium, at least on Bitmovin demo. If it doesn't work for you, try OpenWV.
  5. Originally Posted by Henryk69 View Post
    Just checked with the latest Chrome and the installation as well as functionality with Amazon Prime FREEVEE is working fine. (I know that the screenshot was taken on Firefox but both work)
    Your video not downloading has nothing to do with WidevineProxy2
    [Attachment 87400 - Click to enlarge]
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  6. Originally Posted by larley View Post
    It is true that it works if it has not been deleted, I installed a new Windows 10 and a new Chrome and it stopped working, Chrome does not accept this plugin, I do not want to install it, it simply does not see it
  7. Yes because chrome doesn't accept XPI files, they're for Firefox. Just drag-and-drop the .zip file into the Extension overview window.
  8. Originally Posted by larley View Post
    You were right, I dragged it and it jumped. Thank you very much for such quick help, I am so happy thanks to you Larley
    Now I have to find this difficult wvd file, it will take me a while
    Thanks Larley everything works
    Thanks Larley (device_wvd)
  9. Am I doing something wrong or missing something?
    I've tried multiple Widevine Devices and can't ever get any keys...
    Feb 2006
    [Attachment 87450 - Click to enlarge]
    try pining the add-on to the toolbar and try again.
  11. Originally Posted by october262 View Post
    Just tried it.
    [Attachment 87451 - Click to enlarge]
    Still no luck...
  12. It works for me too, maybe try it on another page because it works for me on other pagesImage
    [Attachment 87458 - Click to enlarge]
  13. Originally Posted by Henryk69 View Post
    I've tried on others as well. It's not working.
  14. Originally Posted by pesfacemaker View Post
    And I tried refreshing the browser page several times
  15. Maybe it's the browser giving you problems try it on another browser, on Edge and on Chrome it works fine
  16. can you add a section to show request data and response data in dev tools network section
  17. Originally Posted by pesfacemaker View Post
    Make sure Firefox is on the latest version
  18. i've been using the tool it's really amazing, main problem for me is that it doesn't fetch the subtitles for some reason any idea? i can just f12 and search for ttml2 but that requires time
  19. If they're not referenced in the manifest then there's not really a standardized way of getting subtitles. If they are, but aren't shown in N_m3u8DL-RE, then that's a problem with the downloader.
  20. Yep i've realised that, just read in page 11 of this thread and finally ended up using this no drama tool https://github.com/Tithen-Firion/UserScripts
  21. Originally Posted by larley View Post
    It is. Does the extension work on its own or does it need something else installed in order to work?
  22. No, it should and does work on the latest version of Firefox/Nightly, Chrome and Edge
Name:	Screenshot 2025-06-17 223734.png
  23. Originally Posted by larley View Post
    Well just checked, I do have Firefox updated but it's not the latest version. Guess the extension won't work for me.
  24. Originally Posted by larley View Post
    the key for my url.mpd keeps changing, do you have a script to use through the extension to get the key
  25. Good day to all
    In this example Lomero showed that it works on this page and therefore the program is fine.
  26. How can I get 5.1 sound for Amazon? The 2 channel download option always appears
  27. Originally Posted by ibra View Post
    im also interested how to do this
  28. Member
    Apr 2024
    Warszawa
    audio 2.0
    https://s3-dub-ww.cf.dash.row.aiv-cdn.net/dm/3$0ChoIAiBdMAFSBoDAAoHwA3oDgLgXggEBAYgBBBgB/972f/be96/7726/4816-b2e7-3f0db868ab0b/7cc21a50-1019-45d2-8f94-dafac984fd0e_corrected.mpd
    audio 5.1
  29. Originally Posted by mario_2000 View Post
    audio 2.0
    audio 5.1
    got it. you are the final boss haha
